Erster Patch / Build 60 released
Update notes below taken from the readme.txt file in the rF2 directory after installation of Build 60.
UPDATE 1 Changelog (Febuary 15, 2012):
MULTIPLAYER:
Configurable multiplayer race countdown timer ("Race Client Wait" in multiplayer.ini).
Reducing collision work in multiplayer (including completely turning off remote car vs. scene collision for now) in order to prevent slowdowns.
Modifed Dedicated server and mpfile to allow/disallow nicknames.
Fixed in-car chat for extended ASCII characters.
Fixed showroom sun occlusion problem.
Fixed sun occlusion toggle.
Improved HDR debug output.
Moved all HDR processing to GPU.
Now enforcing deformable meshes.
Fixed and improved "visible vehicles" algorithm.
Updates to static meshes now disabled.
Fixed AI brake lights.
Fixed some issues doing HDR/Post on monitor.
Fixed up some postFX problems.
Updated sun occlusion.
Improved post FX integration with HDR.
Dixed bug that could result in cam file having more shadow parameters than the array that holds them.
Fixed problem with using post with HDR.
Fixed up hdr debug output, also improved post-processing.
Tidy up line drawing, also deactivated pre-caching for now as a test.
Fixed up hdr debug output.
Fixed a crash when loading a new profile to an existing track.
Shaders are recompiled if vid driver or HDR changes.
Reverted virtual mirrors back to using options settings rather than video settings.
UI:
Fixed car skin spinner not selecting current selected skin when entering screen.
Fixed path error for loading truetype fonts.
Fixed car spinner gizmo bug where it selection didn't take into account pace cars in the veh list ordering. (so picking a car near the end of spinner would select the wrong car.)
Fixed crash from skin selector gizmo that would happen 1st time you join a online game for a new mod and go to tuning from car selector screen.
Fixed bug where one couldn't select a new UI.
Fixed gear graph text in wide-screen mode with non-wide-screen UI.
Tidy up some loading bar problem.
Fix HUD pit menu selector box.
Added tire volume slider.
Added new options for VSync and FXAA.
Extra code to prevent ramming from behind when attempting to pass.
Generally made AI initiated player crashes less likely.
Made line transitions safer (for example moving from fastest to blocking line).
Fixed exaggerated pitspot slowdown.
Implemented 1st round of VERY basic wet weather tire logic.
Now always simulating a lap once for every car to get fuel, time, and minimum speed for track (to improve AI pit strategy).
Made AI slower at 70% by not only reducing their grip (was already being done) but also cutting a bit of speed off corners on top of that when figuring.
Made AI cars more likely to pass another car in the straight if given the opportunity.
GAMEPLAY:
Fix for timescaled mechanical failures.
CONTROLLER:
Added controller.ini variable "Off-road multiplier" at least until we have proper soft terrain physics modeling.
Changed default for "Keyboard Layout Override" in controller.ini to 1 which seems to work better most of the time.
Added new controller.ini option "Use Keyboard Rates For Analog" which allows gamepad users to intentionally delay the response time of their twitchy inputs.
Added controller.ini variable "Use Hardware Additional Features" to control whether we play G27 LEDs, for example. Actually that's the only example right now.
Added ability to read/write Thrustmaster wheel range (only available on new T500RS series, by the way).
Set default control for 'Display Vehicle Labels' to TAB key.
OTHER OPTIMIZATIONS
Various collision optimizations, including better automatic LODs for trackside collidable objects.
Fixed crash that occurred when no sound devices was enabled on Windows 7 Machine.
Improved and/or fixed OnTop variable in TDF - this is a precise way to physically apply paint stripes on top of the road with a realistic thickness.
Minor SSE optimizations added.
Vertical position of individual mirrors wasn't being transferred from CCH file to PLR file (note that these values are not editable in realtime with the Shift/Ctrl/Alt + Seat position controls).
Fixed dedicated server not updating scoring for plugins.
Fix for "Unknown" name in player file.
Fixed wide characters aborting the results file write.
Mirror toggle control lets you go through all 5 permutations in cockpit now.
Fixed a potential problem alt-tabbing with SL.
FUNCTIONAL ADDITIONS:
Allow nickname and attempt to allow wide char names.
Added a "Steering Wheel" option for "No Arms".
Added user car skin support.
MOD/PACKAGING
Fixed a bug with packaged files which could have allowed tire data to be overridden by external components.
Fixed a minor issue with encrypted mas.
Fixed ttool crash. -
Im Rennen ist die Performance schlechter geworden obwohl ich mehr FPS habe, zumindest im Training.
Was wirklich hilft bei der Performance ,zumindest bei mir und paar anderen ist, wenn man den player Datei löscht.
Wie jetzt? Du löscht jedes mal die player.plr um mehr Performance zu haben? Das kann ich mir beim besten Willen nicht vorstellen. Ich würde eher sagen du hast was verstellt gehabt, und wenn man dann die player.plr löscht, legt rFactor2 beim nächsten Start ne neue mit Standardeinstellungen an.
Nein ich habe es nur 1 mal gelöscht.
Ich bekam den Tip im ISI Forum. Es ist schon so dass ich seitdem bessere Performance habe und auch mehr Sachen z.B HDR usw einstellen kann. Ach ja und nachdem Patch hatte ich bis jetzt noch keinen Problem mit dem Lenkrad.
Hoffe das bleibt. -
Kann mir mal bitte jemand die verschiedenen Sync-Optionen erläutern? Die Beschreibung im ISI-Forum habe ich schon gesehen und wenn man eh schon weiß, was es damit auf sich hat, dann wird man daraus vielleicht auch schlau... Aber die Vorteile/Nachteile/Funktionen/Notwendigkeit der verschiedenen Optionen erschließt sich mir nicht so ganz.
Hallo zusammen erstmal.
Das mit der plr war bei mir auch. Wenn auch ein wenig "rabiater"
Grundlegend auf der selben Strecke und Einstellungen, hatte ich nach dem Update nicht mehr ca. 80, sondern gigantische 13 Frames.
userdata ordner gesichert, neu installiert, ordner zurück und das selbe wie gehabt.
Erst eine komplette Neuinstallation, brachte ein Schub auf rund 110 Frames.
Dann hatte ich aber das Problem, das sich der Rechner sporadisch auf hängte. Bei nem Screenshot war sofort Schluß.
Wie gesagt, die selben Settings wie vor dem Backup. Dann wollte ich was im CCC ändern. Ich hatte dort noch nen Profil erstellt.
Habs gelöscht um mal zu schauen...nu lüppts wieder.
PS
War der Scheibenwischer auch schon vor dem Update da? Der hat ja sogar 2 Geschwindigkeitsstufen
Der Scheibenwischer war schon vorher mal da. Und ja, er hat zwei Stufen.
Benutzer online 1
1 Besucher
