rFactor2 Build 125 released!
  • rFactor2 Build 125 released!
    isiforums.net/f/showthread.php…actor2-Build-125-Released
    Auto Updater:
    Ladet bitte das Update runter und installiert es manuell. Der Autoupdater steht für das Update diesmal nicht zur Verfügung. Kommt aber wieder. Oder ihr benutzt den Fullinstaller für den aktuellen Build. Alle Links finden ihr im oben genannten Link zum Releasethread.
    Build notes:
    UPDATE 9 (Build 125) Changelog (November 30, 2012):
    Improved lighting in car paint shaders
    Fixed a bug with generating bboxs for procedural meshes, which was causing problems with shadows
    Leaf wind now working again in shaders
    HDR profiles are again active; packaged profiles will be auto loaded from track component mas files; user-defined profiles are loaded from Player\Settings\track_layout dir
    HDR profiles can be loaded from the Settings menu in the real-time monitor
    prevent 'Auto Detail FPS' from LOD'ing the currently viewed vehicle
    Added support for loading user shaders
    Attempt to improve LOD level flashing while regulating frame rate
    Re-enabled transparency AA setting
    Fixed issue with visual tire wear on AI vehicles
    GAMEPLAY:
    Fixed/changed behavior where we wouldn't use weather settings unless you had actually visited the weather settings page; this was confusing so we always use your saved weather settings now.
    Made track-cutting thresholds configurable in the GDB.
    PHYSICS:
    Fixed some RealRoad setting issue and uninitialized data if file couldn't be read. Note that we had to add a checksum to RealRoad files so the format has changed slightly.
    fixed a bug where AI ignored pit strategy needs while out on track.
    fixed issue of AI cars constantly trying to pit for tires if the only tire compound available is a wet road compound.
    added two new variables for AI to the RCD files "UnderSteerEffectOnThrottleMulti" which you can raise higher than 100 if you want AI to more quickly get off throttle when he detects understeer & "UnderSteerEffectOnLineMulti" which you can raise lower than 100 if you want AI to more quickly adjust line wide when he detects understeer.
    hopefully improved AI trainer tendency to spin on high speed corners by lengthening distance we look ahead for disappearing road and slowing rate of lateral movement based on how much lower than 1.0 new RCD parameter "UnderSteerEffectOnLineMulti" is.
    UI / HUD:
    added code that hopefully prevents un-selectable (according to the veh file) cars being selectable
    fixed event picking bug when a MOD with multiple updates has multiple versions of some events
    fixed bug in HUD editor that had mismatched global parameters.
    Made RFM picker scroll in when ARAC button is selected.
    fixed extra character being drawn for newlines in the garage notes
    Add selectable HDR profiles to settings page
    Added a new Options Button to select "All Tracks & Cars". Also removed "All Track & Cars" mod from the spinner.
    Added version numbers to RFM, VEH, & track selection gizmos.
    Fix for showroom not loading first time through
    added gizmo to off-line player monitor page that lets you pick specific AI to add to game.
    made the "leave track" gizmo from the maximized monior page into a new gizmo type that hides itself if no in the dedicated replay mode.
    changed the vehicle labels font to a true type font (to hopefully catch all the foreign characters)
    BUG FIXES:
    Fixed problem where upgrades didn't work first time after installation
    fixed potential deadlock when adding or booting AI in single-player mode
    Fixed a bug to allow mas'd sounds to be loaded in moddev mode
    MULTIPLAYER:
    Fixed it so client gets message if they are being kicked out due to vehicle upgrades changing their class to a disallowed type. Also added to the message what the allowed classes are.
    CONTROLLER/FFB:
    Now also resetting steering wheel range whenever 'Reset FFB' is pressed.
    Bumped up maximum number of controllers from 4 to 6.
    Added logging and potential fix for problem where people sometimes lose keyboard input.
    PLUGINS:
    We continue to recommend not releasing plugins based on V05 of the interface until it is considered final.
    REPLAYS:
    Added ability to resume a session from a replay, which acts like a continuous save file. You can choose any car at any point in the session. While you can use a replay of a multiplayer session, you can currently only resume it as a single-player session. Note that the replay is not and will never be a "perfect" save file, and currently there are some vehicle states that are not properly restored, in particular the state of your tires. Note also that this feature changes the replay format and is not backwards compatible.
    MODDING / PUBLIC DEV
    Fixed a bug in Mas2 with crashing during mod install
    Fix for viewer to support no dyn vbuf
    Removed confirm dialogs from Mas2 for mas'ing and packaging components and mods
    Changed multi-cmp file extension to .rfcmp
    Minor changes made to improve meshmender tangent basis generation
    Alternate tangent basis generation is now available, this may be a better choice in certain cases, but most likely won't be
    gMaterial plugin now only requires .GFX (shader description) files, complete shader code is no longer necessary to get shader list
    gMaterial plugin now prompts (first time only) for location of .GFX files or MAS file containing .GFX files
    gMaterial plugin now searches all MAS files in the GFX file location for shader desc files
    gMaterial plugin has a "Reset Shader Location" button at the bottom, after restarting 3DS Max, you will be prompted again for shader desc file location
    Added fix for loading mas'd sounds in mod mode
    RealRoad loading dev-mode fix, plus a slightly forgiving checksum for RealRoad files in case track makers make minor tweaks to vert locations for seams or whatnot
    fixed corner cutting corridor manipulation to match regular corridor manipulation (moves 10 times faster and left alt to slow it down)
    made changes so that you can adjust Message center and chat fonts on the fly from HUD editor.
    Added sample vertex and pixel shaders in Moddev\Shared which demonstrate how to use ISI macros in add-
  • Spacekid schrieb:
    Heißt das, dass die AI jetzt mal mit glaubwürdigen Boxenstrategien vorgeht? Oder spulen die nach wie vor treudoof ihre Runden ab und kommen z.B. in der vorletzten runde zum Reifenwechsel an die Box?
    Spacekid schrieb:
    REPLAYS:
    Wird es denn mal eine richtige Save-Funktion geben?
  • Baule schrieb:
    Spacekid schrieb:
    Spacekid schrieb:
    REPLAYS:
    Zu Frage 1. Ja, sollten sie eigentlich machen.
    Zu Frage 2. Ja, irgendwann gibts auch ne richtige "Save" Funktion. Hoffentlich. ;)
