youtube.com/watch?v=ZL7T9BD_Q3k
incredible 8|
http://www.loaded.se/sd_page/30/1/index.php?Car: BMW M3 E46 CSL 2003/07
Engine: 3,2 L Supercharged engine, new low-comp pistons,10,5:1 compression,Vortec
V2 Super silent with water-cooling system, extra oil cooling system,
new fuel system with catch tank and Bosch fuel pumps. Extra
oilcoolersystem with Modified oilfilter housing, Carbon fibre
enginecover. Carbon fibre airinduct. 55 degrees water thermostat.
RWHP: 532,71 / 0.85bar / 98 oktan fuel
Torque: 483,67 / 0.85bar / 98 oktan fuel
Suspension: KW 3-way adjustable race kit
Chassie: adjustable front camber platesfront springs 120 mm + helperrear springs 100 mm + helperprepared front wishbonesexcentric caster bearing kit3-way adjustable anti-rollbar + uniball thrust-rodsstiffer rear frame, changed kinematic pointsaluminium bushings (frame)aluminium bushings (final drive cover)excenter uniball bearings (camber)center uniball bearings (tow)center uniball bearings (top arm outside)stiffer rubber bearing top arm insidealuminium machined lower arm + uniball bearings2-way adjustable anti-rollbar + thrust rodsprepaired drive shafts + vent system
Frontbrakes: AP 6 pot caliper, PFC 355 mm Ø disc, PFC 01 race padsINOX brake line system, brake vent system 80 mm Ø.
Rearbrakes: AP 4 pot caliper, PFC 323 mm Ø disc, carbon race pads, INOX brake line system
Frontwheels: BBS GT split, F18"x10 ET 40, 15 mm spacerdiscs, Tiresize 265/35/18”
Rearwheels: BBS GT split R18"x11 ET 35, 12 mm spacerdiscs, Tiresize 295/30/18"
Tires: Michelin pilot Sport Cup R tires
Rims: BBS Racing 18" Sandmold magnesium center with forge aluminium lane
Exhaust: Supersprint lightweight racing all the way.Spec: 100% Stainless exhaust system, Oversize 2x Ø 60 mm-Manifold. (LHD)-Front pipes kit.-Replaces Kat.-Centre exhaust. 76mm LIGHTWEIGHT RACING EXHAUST-LIGHTWEIGHT RACING EXHAUST Rear exhaust OO 80 R. + OO 80 L
Drive train/clutch: 3:91 ratio differential, Sachs Sinterclutch kit.
Exterior: Carbon fibre roof, hood, trunk, fenders, front and diffusor.
Interior:
bolted rollcage light version (25 kg), adjustable Recaro race seat
system with 6 points harness. A lot of carbon fibre interior as
standard CSL
incredible 8|
